06-22-2023 09:38 PM
Hello,
I would like to port my number to Telus and keep my plan with Public Mobile but get a new number. Is that possible?
06-30-2023 10:50 AM
Policy @computergeek541 ?
If a user is proposing it as a means of staying within the TELUS groups of family, why wouldn’t they do it?
policies at companies are almost always bent when it means additional revenue for them.
06-24-2023 01:58 AM
@HALIMACS wrote:Because Telus and PM are within the same group of companies, if you were to change your number here with public mobile, and had pre-arranged for Telus to pull your existing number there, they may be able to do this.
It would just take some level of coordination between Telus and PM.
It's always been possible that it could be done, but policy forbids it.
06-23-2023 06:19 AM
06-22-2023 10:15 PM
You will need to get a new SIM and pay for a new plan/number with PM. At the same time, if you port your number to Telus…you will be paying for 2 plans and will need two phones or a phone with dual SIM tray.
It would be better to download the TextNow app and get a new number to get free wifi calling and texting for the second account.
06-22-2023 09:44 PM
@KandyKayne once you ported out your number, account will be closed.
You can't pick a new number for your current PM plan either as you will loss your current number and hence can't be ported. There is really no workarounds
06-22-2023 09:40 PM
@KandyKayne No you can’t . You would just have to get a new Telus or give up the pm line if your port it out
06-22-2023 09:39 PM
No.
