12-26-2024 03:56 PM
I would like to keep my old number and plan but my only option is to buy a new sim even though i have my old e sim number. I cant go to my account and just update my plan, it keeps bringing me to the activation page.
12-26-2024 06:01 PM
Hi,
I have a Puk code issue, and couldn't login to my portal, as sms was sent to my number to authorize login. I had to use the email to recieve the code, then I was able to access my portal and paid for my plan, and that saves my number. However, I still have a puk code issue.
12-26-2024 04:14 PM
get PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here
12-26-2024 04:00 PM
@Wife2 try reaching out to a support agent for assistance.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
