03-28-2019 07:26 PM - edited 01-05-2022 07:01 AM
03-28-2019 10:47 PM
You could change to a plan with more data to reduce chance of running out next time. How many days left did you have remaining? It was very early running out, I would take a plan with more. No need to wait for mod that way. Think carefully about doing that if your plan is not still available for new customers or you won't be able to get the old plan back.
03-28-2019 07:53 PM
Thanks 4 the link. Youre awesomeness is greatly appreciated !
03-28-2019 07:53 PM
@jackjacobedward wrote:Because I haven't no more than one reward, commencing my pay period a day early is in my best interest. P.s.You guys r awesome!
As a rule of thumb, it is usually frowned upon to mark your own reply as solution with others' help.
03-28-2019 07:51 PM
03-28-2019 07:43 PM - edited 03-28-2019 07:48 PM
@jackjacobedward you could buy the add-on. If you don't use it all, it doesn't expire. Renewing your plan early can sometimes cause problems with your awards/credits, which can be fixed, but would take time going back and forth with the mods.
03-28-2019 07:29 PM
If you do so before your renewal date you will loose the rewards for this month ..if you have some and what is in your plan... the next renewal date will change...It's not a good idea to do it before. Make your calculation..
03-28-2019 07:28 PM
Yes, if you like you can add additional funds to your account, and then message a Moderator to start your next pay period early:
03-28-2019 07:27 PM
Early renewal requires moderator intervention. Ask a moderator (Can take up to 48 hrs, 1 message at a time).
If this solves your question, please select my reply as Solution!
