12-26-2022 02:54 PM
Can I get a pro-rated refund when I port my number out to another provider before my current billing sycle ends?
Payment
12-26-2022 07:21 PM
this answered hours ago!!!
12-26-2022 07:11 PM
No pro-rated refunds from PM
12-26-2022 06:58 PM
This is PREPAID
P R E P A I D
Is PM porting you out? No right, you are doing so, because you want it, so swallow it!
12-26-2022 03:01 PM
@qswupublic No, PM is a prepaid provider and do not provide prorated refund. So, you should time your port out time better. But do not wait till last day as porting process can have hiccup , from PM or from your new provider
Usually, it is best and safest to port around the 25th days , it gives both carriers enough time and minimize your loss
One thing, if you are porting into Koodo or Telus, call their agent and them them you came from PM , they might be able to do something to offset the money you lost
12-26-2022 02:58 PM
@qswupublic Nope
12-26-2022 02:55 PM
@qswupublic @No pm is prepaid , so no refunds unfortunately
