Can I get Public Mobile to generate me a different friend code??
Jessica7
So... long story, but anyone know if I can get a different friend code?
Like the code I send to people to sign up, can I get a new one??
I know an odd thing to say...
@Jessica7
as far as I know,  you have the same code on the same account
curious,  why you need a new code?
dust2dust
Yes, mixing letters and numbers can be easy. You need to explain that the particular letter or number is that letter or number. When I give the code I explain which is which to them.
will13am
@Jessica7 , I have not come across this request before.  I would think that in the background, the referral code is used to link ongoing referrals to an account.  Changing that could really cause a mess.  Why would you need a new code anyway?
@Jessica7 - do you have characters that get mixed up easily? kinda of like 0 or O ?
When you share your code as the friend to copy and paste it, so it uses it accurately.
Not likely can get it changed, but you can ask a CSA. Bo to the bottom of the Community page to submit a ticket with Customer Support using the SIMon Chatbot option if you like.
@Jessica7
Sorry, nope…it is automatically generated by the system when you activated your SIM.
I would copy and paste your referral code and send it to your friend so there are no mistakes while entering when activating their SIM.
