US Roaming not working
PatPublic44
I purchased the US roaming for data, calls and text.  When I was at US, they were not working.  Please review.  Thanks
@PatPublic44
You will need to connect to T-Mobile network to work but where were you in the USA?
If you are back in Canada, contact a CS_Agent for a refund.
@PatPublic44
which state and city you were at?
did it connect to T-Mobile?
since you are back here already, I guess you can open ticket with PM support and ask them for a refund
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
dust2dust
Are you home now? Was that a re-purchase from having one immediately before?
