07-28-2022 01:27 PM
I was on a grandfathered $50 plan and I changed to the $15 plan. Immediately afterwards I realized that I'm going to need unlimited calling so I'd like to upgrade my plan to a $25 plan but I'm not willing to pay $40 for a $25 plan. Is there any process or support to fix my mistake?
08-08-2022 07:37 PM
@silfur wrote:I was on a grandfathered $50 plan and I changed to the $15 plan. Immediately afterwards I realized that I'm going to need unlimited calling so I'd like to upgrade my plan to a $25 plan but I'm not willing to pay $40 for a $25 plan. Is there any process or support to fix my mistake?
Did you request an immediate plan change or did you pick the scheduled option? The scheduled a next renewal option can be backed out of.
08-08-2022 12:53 PM
08-08-2022 12:40 PM
@Meow Sometimes, CSAs will use their discretionary powers to assist a customer making this kind of adjustment if the plan cost difference has been added to Available Funds.
@silfur If the $25 plan is not required for the its data allowance, adding $5 calling add-ons as needed may average out cheaper. After all, incoming calls are unlimited so you only need to "bulk up" for outbound calls.
07-28-2022 08:29 PM
You can switch to the $25 plan from the $15 plan but unfortunately you can’t go back to the grandfathered $50 plan.
07-28-2022 01:38 PM
There is no way back.
Since you are on $15 plan now, you can add 500 minutes add-on, and schedule plan change to $25. So you are going to 'suffer' 30 days with only 100 minutes out calls and after that will have unlimited.
07-28-2022 01:32 PM - edited 07-28-2022 01:34 PM
Nope...unfortunately, once you opt out of the "grandfathered" plans...you can't opt back in as they're no longer an avialble plan. Sorry !
You can get the $5 / 500 minutes of Canada wide calling add-on for use if you run outta minutes in the $15 plan. Then you can select the $25 plan to Change at next renewal.
