Can I cancel a purchase I just made
Polyian1
I just purchased a 3 GB data add-on. I didn't realize it expires in 30 days. I am leaving Canada soon and I cannot use this data in 30 days. Can I cancel the purchase?
Thanks for your help
@Polyian1 they usually reply within an hour or two.  Worst case, if you don't hear anything in couple hours, message them again .  But remember to check Community inbox for their reply
Polyian1
Thanks, I have done what you suggested...waiting for a response
@Polyian1
PM is a prepaid provider and usually do not provide refund
However, if it was an honest mistake, they might be able to help and reverse the transaction, please engage them here
@Polyian1  You need to ask support if they can reverse it for you
private message   To CS_Agents click
