Einaty-paz
I Set up a new Public Mobile account an hour ago, but cannot transfer my number as i made a typo. i am trying to get some help and am unsuccessful - I haven’t been able to get the support I need from Public Mobile online support to understand and fix this problem. Can’t submit a ticket as all codes are sent to the wrong number. reasons-  Leaves me with no options other than cancel my account and look for a different provider.
1 REPLY 1
hi @Einaty-paz no need to cancel , there is a porting assistant group you can call.  I will send you the number to your community inbox.  Call them and they can update the correct info and resubmit the port
