02-02-2024
05:00 PM
02-02-2024
06:25 PM
computergeek541
I am going to purchase a cell phone esim and 90 day plan from Mint mobile in the USA. I am wondering if I could forward my Public Mobile cell number to this USA phone number with mint mobile.
Thank you in advance for your help.
edited by computergeek5441: this discussion is unrelated to the Community category
02-03-2024 12:27 PM
@Grinch wrote:Would it work if you have some US calling minutes?
Unfortunately nope... I have an add-on for long-distance calling to the US, and can confirm I still cannot forward to numbers in the USA.
02-03-2024 01:40 AM
02-02-2024 10:44 PM
I also recommend TextNow as an option as @hairbag1 suggested, as they give you a new Canadian number you can call forward your Public Mobile line to. Then, you can continue to receive calls via TextNow over Wi-Fi or mobile data provided through a SIM card/mobile network in the country you are visiting.
Keep in mind though that since you are travelling to the USA, call forwarding will stop working if you let your phone register to a USA tower, so I recommend you physically remove the Public Mobile SIM from your phone while using the Mint mobile service to ensure it doesn't accidentally do so.
A nicety of TextNow would be that even if you don't manage to answer a call to your TextNow number, or the call came when you had no or spotty Internet service, you can still receive the voicemail notification once you do get back online.
If you don't forward, you can still occasionally check your voicemail messages by calling one of the numbers on this list I collected/developed a while back of all of the known Public Moible (and Telus & Koodo) voicemail access numbers across Canada: https://productioncommunity.publicmobile.ca/t5/Get-Support/Updated-list-of-Voicemail-Access-Numbers/...
Another option is to signup for a free YouMail account, and forward to the local Canadian voicemail deposit number they give you in your instructions. They will also email you notifications of new voicemails which you can listen to from the link in the email without even having to install their app, or get a few more features and text transcription if you do...
02-02-2024 06:36 PM
not sure if this will help but you can forward calls to free VOIP apps such as TextNow. Use your Mint data or local wifi for TextNow.
02-02-2024 06:25 PM
@will13am wrote:@cully19611 , from what I recall you cannot call forward to a US number. Sorry.
I can confirm that Public Mobile does not allow that.
02-02-2024 05:07 PM
Thank you
02-02-2024 05:02 PM
