Can I call anywhere in Canada? I can not call anywhere except local
Qizhong
16 REPLIES 16
@Qizhong   Is this just one particular number in 604 area code, or is it any number in that Vancouver area?  Just wondering if the problem might be at their end.  What happens when you try to call, do you get any kind of message?
Qizhong
I just checked my plan: it should include Canada wide calling, but I can not call
how long you joined? what plan you have?
if you joined recently , it will call All Canada calling for sure
but ask PM to check your account using the link I provided above
@Qizhong  We are just customers like you trying to help we cannot see your plan . If you want customer service to check you have to message them
send  a  private message   To CS_Agent
Qizhong
Can you check my plan and tell me: wether I can call anywhere in Canada or not?
Qizhong
I don't
Qizhong
I do have details on my plan!
It just say how many G included in my plans
@Qizhong  Go to your account payment page and screen shot the plan you have for us . I’m wondering if your in a old province wide plan
Qizhong
Yes, I did put 1 in front of the number
try calling with a 1 in front
and try reboot the phone
if still not able to call, ask PM to check the account settings
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
@Qizhong Are you putting a 1 infront of the area code  and phone number ?
Qizhong
I have tried to call 604 area, not getting through
Qizhong
No
I can not.
I have tired but only to area of 902, not 604
@Qizhong  yes if you have Canada wide plan and not a province wide only plan . Be sure  to use 1 infront  of the 10 digit contact
HI @Qizhong
you should be.  Most of us have Canada Wide calling (only very small number of subscribers got Provincial calling plan from before)
slusagm
yes you can
