01-03-2021 12:24 PM - edited 01-05-2022 04:42 PM
Hi there,
Was wondering if I can activate a new plan with the Boxing Week Savings plan?
I have been with Public Mobile for the past 2 - 3 years? I couldn't really get a straight answer from the moderator ... So had to come here.
https://publicmobile.ca/en/on/boxingweek -> link to the promo plans
01-03-2021 03:11 PM
Hi @babu62
I'm pretty sure you mean by retaining only just your existing account - correct?
If so, no.
As others have said, if you register ANOTHER e-mail address for the promo, and activate a second plan using that other e-mail by January 15, then yes.
01-03-2021 03:05 PM
You can always purchase a new card and get new customer deals. But the thing is you will lose loyalty discount and get a new number.
You should ask is it worth it?
By the way, as an another option you can use second sim until you consume all your data/minutes or expire date. Then you can throw sim card away and cancel the account.
01-03-2021 02:19 PM
i guess you meant can we take advantage of the new promotion/plan..
not with exiting account
you will have to create new account.. but you can use yourself as the referral....
But, you can't port your number from your old account to your new account
so, you will end up with 2 lines.. if this is what you want.. 🙂
01-03-2021 12:31 PM
Yes, but then you will have two accounts/SIM cards/phone numbers. Unfortunately, you can't port a PM number to another PM number. If you are not stuck with your previous number, you can let the 1st account expire (if you don't need two numbers). You will lose whatever loyalty, friend rewards also. Some customers in the past have ported the 1st number to another company, then port back to 2nd account. However, there are costs to that method, etc.
01-03-2021 12:26 PM
I'm not sure how such a straight answer could be straighter...yes. But it's whole other new account with new everything.
