Calls to mobile going directly to voice-mail
WayneCollins
Incoming calls to my phone are going directly to voice-mail without ringing on phone. Out-going calls are fine. What is going on ?
7 REPLIES 7
Cell_Mate
Hmmmm I have the ringer way up and not on Do Not Disturb.... following this thread as it's possible I have the same issue.
Cell_Mate
I believe that may be what I am experiencing as well... not sure though. I do know that sometimes I hear the ring and other times not at all only to realize later that I missed a call(s).
WayneCollins
Actually it was set to "Focus on Work" not sure how that happened, but once turned off, problem solved.
Thanks
@WayneCollins
Go to Settings>Cellular>Cellular Fata Options>Voice &Data>click on 3G to see if that helps.
WayneCollins
Where do i change that ? (on iPhone)
hairbag1
@WayneCollins
depending on which phone you're using...could be you have it in Do Not Disturb...or maybe you turned ringer way down.
HI @WayneCollins
some network issue.
change the network to 3G or WCDMA only and leave it for couple days
