Calls directly to voicemail
Lblaine
Phone calls go directly to voicemail. All other phone features work and I can call out now problem. Phone plan is up to date and paid. Started happening today.
Cheers
Lee
10 REPLIES 10
@jch1 wrote:
same problem but mine was ported, but I could use it before and suddenly can't receive phone calls starting yesterday
Was your number port completed successfully?  Is the old service no longer functional?  If the number port was not completed, the old service might still be functional and calls are routing to the voicemail at the old service.
Lblaine
Thanks dabr your solution worked perfect.
@Lblaine wrote:
iPhone 13 mini
I am not an iPhone user so I am not at all familiar with the menus.  Try looking up the call forwarding option for the dialer and see if the forwarding has been set to have calls go to voicemail.
Lblaine
iPhone 13 mini
DDM69
iPhone or android?  Check that you don’t have focus activated and check any other incoming call settings.
Lblaine
I’ve got other family members on public mobile and their not having any issues.
@Lblaine  & @jch1     Try moving your SIM to another phone and then back.  Almost seems this issue is becoming a trend as another customer also reported something similar and said using the SIM in another phone temporarily and back resolved it for them.
Here's a link:  https://productioncommunity.publicmobile.ca/t5/Get-Support/Unable-to-receive-calls-sms/td-p/828917
jch1
Lblaine
Just started this morning. Phone and service has been working fine for  the last couple years.
will13am
@Lblaine , is this a new activation involving a number port or is this an existing account for which this problem occurred out of nowhere?
