05-30-2022 01:33 PM
All incoming calls are going to VM and incoming texts are not coming through.
Have restarted a few times. Have manually and automatically selected network operators. At a loss. Been going on for a few hours now.
How do I contact support??
05-30-2022
04:20 PM
05-30-2022
04:32 PM
computergeek541
i have the same issue, i'm not the only one
05-30-2022 03:31 PM
@stally89 Yup, that could have helped. Putting the SIM in another phone triggered a provisioning to your account/sim.
05-30-2022 03:07 PM
@Coyote2 Hi all, did everything possible from my end. Support refreshed services from the back end. I then turned off my device and removed some cars and restarted
Still no luck.
Finally I swapped sims with my wife's device (same one) and all the messages came through and calls worked too.
Working fine now.
No idea what caused it.
05-30-2022 02:24 PM
05-30-2022 02:23 PM
Same here. Also getting extremely poor data speeds now that I checked. 0.3 Mbps...
05-30-2022 02:22 PM
I have the same problem this morning and have submitted a ticket. I am waiting for a response for a live chat.
This is the first time I have had a problem and tried this Community thing.
05-30-2022 01:38 PM - edited 05-30-2022 01:45 PM
I do have signal. I am able to make calls just fine and use the internet.
Thanks for providing steps on contacting support.
05-30-2022 01:38 PM
Do you have any signal at all? Usually calls going to vmail is caused by no connection to cell tower(s).
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
