04-26-2023 11:09 AM
I see this has been asked in the past but I only see the resolution to get a refund. I’d like to — no have to call the uk- I’ve added the extra minutes but am unable to call I keep getting
8uv1 - your call cannot be completed as dialed. How do I dial to the uk properly? Thank you
04-26-2023 11:28 AM
If you don't know how to dial the number then perhaps get somebody in UK to call you.
Just long enough so that you can add the number to your contacts and see the format you need to dial.
04-26-2023 11:25 AM
011 and + are generally interchangeable. Try dropping the 0 after the 44. Leading zeros don't usually work from here as far as I remember.
04-26-2023 11:25 AM
@Hollister for LD, either use + or 011
04-26-2023 11:24 AM - edited 04-26-2023 11:24 AM
04-26-2023 11:24 AM
Try w/o the + and use the syntax in my first post.
04-26-2023 11:21 AM
Login to Self-Serve, confirm the UK Long Distance add-on has been added and that it is active.
Paying for the add-on and activating the add-on are sometimes different steps.
04-26-2023 11:19 AM
Hi!
thank you for your quick reply!
the number I have starts +440370 do I still need the +?
04-26-2023 11:15 AM - edited 04-26-2023 11:15 AM
You have the UK add on?
If yes try:
To call United Kingdom from Canada, dial:
011 - 44 - Area Code - Land Phone Number
011 - 44 - 10 Digit Mobile Number
