10-20-2025 05:00 PM
10-20-2025 05:09 PM
Because all calls and data are routed back to Canada first when you are roaming, so calling UK from Mex would be the same as you call UK from Canadian. 011 - 44 - Area code - rest of the number
And make sure you drop the leading 0 in UK area cose
10-20-2025 05:06 PM
I have 1000 minutes in my plan. Do you know what dialling codes I would use from Mexico to UK?
10-20-2025 05:02 PM
Yes, if you have the Can US Mex roaming plan and you have the right add-on to call UK, you can call UK when you are in Mexico
10-20-2025 05:01 PM
hi @Rapata
yes, you can
