Call display not working
HuronBob
Hi, I have looked at previous posts and can't seem to find an answer. All incoming calls display "Private number" even though I know these numbers are not unlisted.The only numbers that are displayed are other P.M. numbers. I sure would like to get this resolved.
11 REPLIES 11
@SheBob wrote:
@computergeek541  The numbers were not showing up on the phone exceot for P M numbers. None of my contacts were showing up on the phone when they called unless they were subscribed to P M. They all said "private number" but the issue is now resolvedby having an agent reset the network on my phone.
Thanks for clarifying. I was only asking because the category originally chosen for this messages thread inidcated there being a possible issue with your online Self Serve account.
SheBob
Just so everyone understands, I am SheBob (Sheila) and HuronBob is my husband (Bob) hence "SheBob". We were both working on this problem at the same time so the dialogue trail may look a little strange.
SheBob
@SheBob   thanks. happy that it helped
What is more important is that people get helped 🙂
SheBob
@softech Once again you came up with the solution to my issue. With your community involvement you should be getting your service for free  🙂
I submitted a ticket through the chatbot and soon got an agent that tried a few things before resetting the network on my phone and that seemed to do the trick.
Thanks again
For these incoming calls, is no number being shown on your phone or are you saying that no numbers are being shown in Self Seve?
@HuronBob
Try this.
When someone calls you, create a contact with their name attached to that phone number.  I presume you're using a google account to manage your contacts?
Reboot your device.
Ask them to call you again - does the number display as the contact you just created?
HuronBob
I swapped out the sim card to another phone and had my neighbor give me a call. The problem persisted indicating that it is a network problem I will now contact C S through the chatbot and open a ticket. Thanks for your help. I will let you know how it goes.
@HuronBob   if the same result on another phone, then it is a network issue.  Then please open ticket with PM support using Chatbot.  They can investigate and fix the issue
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
HuronBob
Ok I'll give it a try
@HuronBob   it is like a device issue instead of network
Try to borrow a phone from friend or family member, put your PM sim card there and test it out
If it works on another phone, it is a device problem with yours.  You might need to reset your phone to resolve it
