@CS_Agent
LeiCui
@CS_Agent  I just tried to activate my esim and transfer my old number to it. The service cannot be activated.
1 REPLY 1
@LeiCui   here in the community, we are just customers like you , but we try to help
Are you using Android or iPhone?
At which point you got to? did you get the QR code and did you install the eSIM profile?  If you got pass there, then try a device reboot first.
If still does not work, try to Reset All networks
if issue persists, please open a ticket with Support via Private message for further assistance
