06-23-2023 05:11 AM
I bought the 3gb data addon after it was changed to say "Any unused data or minutes will roll over to your next subscription.". I figured this would roll over indefinitely like before but after I've purchased it I can clearly see the 30 day expiry. I would not have purchased it with the 30-day expiry in place. Can it please be refunded and removed from my account?
09-22-2023 05:03 PM
Know that now, but hit purchase before realizing that the Pm added expiry dates.
Otherwise I would have gotten a 200mb and not the 3gb🥺
09-22-2023 03:55 PM
hi @VeryDiscouraged Yes this is problem with the 30 days expiry. So, only buy enough for use till end of the cycle, don't buy more than you need
09-22-2023 03:40 PM
Same situation.
The kicker when your plan renews it will revert to using plan data and not the soon to expire add-on
06-23-2023 05:15 AM
@Reznale if you have not used it, usually PM support able to reverse the transaction. Especially with the confusing wordings, I think you have a reason to ask for it. Please open a ticket with PM support by messaging them:
