11-24-2019 10:31 AM - edited 01-05-2022 08:06 AM
I bought a SIM card and $40 phone plan at Walmart. The walmart tech set it up on his computer. I received a 4-Digit pin number through my phone confirming that it's working. Then I put the new SIM card in but it never worked. I cant seem to do anything online as it wont recognize my email. I try to register with my phone number but i never receive the 6 digit text pin number that it seems me
11-24-2019 04:02 PM - edited 11-24-2019 04:03 PM
If you use an Android phone, have you change your APN from Telus to Public Mobile? That would help if you are trying to get online.
11-24-2019 03:57 PM
ticket number9476649 the tech at Walmart phoned it in and reset the sim card or whatever so I think I can try online again Myphone was never locked even tho the tech at Walmart told me it was locked
11-24-2019 12:30 PM
@Riphillipm wrote:I bought a SIM card and $40 phone plan at Walmart. The walmart tech set it up on his computer. I received a 4-Digit pin number through my phone confirming that it's working. Then I put the new SIM card in but it never worked. I cant seem to do anything online as it wont recognize my email. I try to register with my phone number but i never receive the 6 digit text pin number that it seems me
Getting those texts means your service is working. Did you check if calls and data are workimg? For faster response, click on question mark on the right side the page. Open a ticket. When you tell it you can't get into self serve, you can use 4 digit PIN to verify yourself.
11-24-2019 12:11 PM
Put old sim back in until it quits...then try the new sim again. Cycle phone off / on..
11-24-2019 12:04 PM
Not working at all. Should i put telus sim card to see if it works? Im going back to Walmart in about an hour
11-24-2019 11:51 AM
@Riphillipm wrote:I received the pin number thru text when i still had my telus sim card I will go back to walmart to see if they can make it work
Is your PM SIM card not working at all? no call, text or data?
If yes, WM rep cannot do much as they need your self-serve account login to change to another SIM card. Create a moderator support ticket first. After moderator determines that you have a faulty SIM card, you can go back to MW for another SIM card.
11-24-2019 11:43 AM
11-24-2019 11:32 AM
From your description, you port you old number to PM during the activation process at WM.
Which SIM card did you received the PM PIN# text message? your old SIM card? or PM SIM?
11-24-2019 11:25 AM
If you were activated at Walmart wouldn't the new PM SIM card already have been put in the phone? You say "then you put the new SIM card in the phone and it didn't work.
Is nothing working with the PM sim installed or do you have outgoing calling and texting, just not receiving incoming calls and texts? If do, port of old number from previous carrier just hasn't completed.
AE_Collector
11-24-2019 11:01 AM
In situation like you, easy way is bring back to Walmart, I believe those tech person may fix for you.
11-24-2019 10:43 AM
While you are waiting for moderator, restart your phone may get your PM SIM card working.
11-24-2019 10:41 AM
Oh yeah and welcome to public mobile and the community:)
11-24-2019 10:41 AM
Is your old sim still available? Can you see if it's still working?
11-24-2019 10:40 AM
You may need moderator help so send them a private message by clicking this link. Then we'll see what we can do here.
Contact @Moderator_Team
About @Moderator_Team
Moderator Hours
Monday-Friday: 8AM- 12AM EST
Saturday & Sunday: 8AM-10PM EST
11-24-2019 10:32 AM - edited 11-24-2019 10:41 AM
Can you restart your phone with the sim inside
Can you try on different phone one you are sure works on Telus network.
You can go to Telus or Koodo store to try it on a loaner.
You can call your old provider to unlock the phone. You can do that through manufacturer as well, although it's probably unlocked
How did you receive the original pin, on your old sim card? Did you port?
For messages and incoming calls you should use the old sim until the port is finished. If it's still not done you may have chance to set up your self-serve.
If you are getting nowhere with it you can contact the Moderators directly at https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Would be useful to have the capture of your receipt handy to show them you are the owner of the account. It's possible that clerk misspelled your address, they should be able to fix it
11-24-2019 10:30 AM
