04-01-2023 07:10 PM - last edited on 04-01-2023 07:27 PM by computergeek541
Hello
I'm going to Boston for 5 days and I've been reading posts about US roaming. It says: to manually select T-Mobile as the preferred network for the phone to work. Can someone explain how to do it, please?
Also, have you had any recent experience with the PM add-on?
04-01-2023 08:13 PM
another PM'er was in Bauston last week and reported that the PM talk, text and data add-on, worked just fine.
It only works for 360 hours from the time you actually buy the add-on. If you plan on staying longer than 15 days...be aware that you'll likely need to wait 360 hours + 24 hours before re-buying that same add-on.
T-Mobile is the only network that will work. See if you can enable volte when you get there for superior talk experience.
Good luck and let us know what you think of the add-on when you return home.
04-01-2023 08:00 PM
Thank you!
04-01-2023 07:19 PM
Hi @c_herrera
for android
04-01-2023 07:16 PM
If it's on automatic then just leave it.
Do you know yet whether you're on volte?
04-01-2023 07:13 PM - edited 04-01-2023 07:16 PM
hi @c_herrera
what phone do you have?
iPhone
From a Home screen, tap Settings . If an app isn't available on your Home screen, swipe left to access the App Library.
2.Tap Cellular.
3.Tap 'Cellular Network' or 'Network Selection
4. Tab the automatic switch off
5. when the available network shows, you can then manual select
