11-01-2022 12:02 PM
Is it only for Ontario or does Alberta get it as well?
Can't find the option in my account.
02-24-2023 01:00 PM
Et nous pour le Québec ce sera possible d'avoir 12 go de donnee
11-07-2022 04:45 PM
Nvm I found the 15 GB talk and text for $40 thanks for the info folks 😁
11-07-2022 04:39 PM
I got the text for the 15gb but it's unclear if it $40 including talk and text or in addition to my $40 talk and text for $40, $80 total
11-01-2022 01:36 PM
I did a recent plan upgrade to $25, back on Oct 19. Taking awhile for PM to update it in my Plan and Add-ons.
Still shows $15, but with 1024MB's of data. I give up trying to figure what happens around here !! 😆
11-01-2022 01:32 PM
@hairbag1- Ok. What amount comes out at renewal? $25 or $15? (disregarding rewards and balance)
11-01-2022 01:30 PM
Sorry...I thought we already ascertained that was a misprint as a result of recent PM site "upgrade".
11-01-2022 12:53 PM
@dust2dust wrote:@hairbag1- You keep teasing us with that $15 1gb plan. How? Will you ever answer that? 🙂
You are right!!! HOw did he get 1GB for $15 plan????
11-01-2022 12:45 PM
11-01-2022 12:42 PM
As long as you can see it on your account it is available for you.
You have to log in and initiate plan change. Then it will appear on a list of plan. It does NOT appear as regular plan.
11-01-2022 12:20 PM - edited 11-01-2022 12:23 PM
Looks like it's still available if you still want it...
For a limited time, get an additional 12GB of data every month for free* for 12 months on plans $40/month or more³.
BUT...
you can get 15gb of data plus talk and text for $40...not time limited either.
11-01-2022 12:04 PM
The 12gb is (was?) for new activations nationwide.
