11-16-2023 04:31 PM
I currently have $25 plan with these add-on:
Changing the plan does not impact the add-ons, correct? If I change my plan to $34 20GB 30-day plan, will I still keep the above add-ons?
Thanks
11-21-2023 06:16 PM
add-on will be kept until it used up . No worries
11-16-2023 04:44 PM
@kb_mv Thank you!
11-16-2023 04:42 PM
@Kanglee You keep any LD add ons until they are used up.
11-16-2023 04:38 PM
Thanks kb_mv.
so it sounds like that is for data add-ons. what about the 500 one-time Int'l LD bonuses?
11-16-2023 04:34 PM - edited 11-16-2023 04:34 PM
@Kanglee You will keep the add ons but if you switch to 5G plan the data add ons will show up as incompatible (unlimited data on 5G plan). They stay on your account in case you ever switch back to a compatible plan.
