12-05-2025 01:09 PM
I just applied for $35 for 60 gb for canada-us-mexico on black friday but do not see this on my account
12-05-2025 01:15 PM
I submited ticket , thank you for info
12-05-2025 01:11 PM
hi @Leontk
did you use Change Now to request plan change?
if you used change on renewal, it won't make the plan change immediately. Change on Renewal will just schedule the plan change.
if you use Change Now and want an immediate plan change, check again. It could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
