Bill Change
03-15-2024
01:52 PM
03-15-2024
04:41 PM
Dunkman
Did anyone else's bill change?
Just 3 days ago, I paid $50.00 ($7.00 awards subtracted from my $57.00 bill). Now I am looking at my bill for April and it is saying I will have to owe $82.00-$7.00=$75.00.
No explanation was given. This is not good at all. I don't have this kind of money monthly!
PM, may you please put my phone bill back to the 57.00 with the $7.00subtraction from my bill please?
03-16-2024 10:45 PM
Thank you. I will. Have a goodnight.
03-16-2024 10:43 PM
HI @Shynell
you probably won't see a true price increase. For my legacy plan, PM will shows the more expensive plan price but will add a credit back to your account to offset the "price increase". So, in the end you are paying the same
But yeah, check with CS Agent and confirm
03-16-2024 10:40 PM
Also, I don't understand how they could increase my plan to $82.00 when it's not even worth that price!?
Is this a scare tactic/marketing ploy to get people to leave the grandfather plans they are in? Please, help me understand?
03-16-2024 10:37 PM
HI @Shynell the system will properly see it as a downgrade by just looking at the plan amount. I think you should check with support agent. They will probably say the same thing initially, but push them to escalate, ask them for a exception since you were on a old plan.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
03-16-2024 10:35 PM
I am curious, how is this a downgrade? I am paying $57.00 for 4 GB of data, Canada-wide calling, international text messaging, voicemail and emergency calling.
The $34.00 plan gives me more for less. This is an upgrade.
03-16-2024 10:29 PM
HI @Shynell
you can make the plan change from My Account's Change Subscription page
But yes, it is a change down, and you will loss the 240GB. You can wait after that 150 days of the data, or if you think that plan give you enough data and you rather have the $$ saving early, then just make the plan change using Change on Renewal
03-16-2024 10:24 PM
Hello again Dunkman,
I like my plan, so how do I contact a customer service agent, please?
Also, if I did switch my plan, would that not take away my 240 GB reward?
Sincerely,
Shynell
03-15-2024 04:35 PM
Looks like that you are on an older grandfathered plan. There was no announcement of plan increase. If you are really attached ot that plan, you can contact customer service agent.
Note starting May 2024, you will lose the autopay and loyalty rewards as per recent announcememt. Legacy reward customers are being switch to points.
Your plan is not really competitive these days. If you want to save some money, consider this plan:
https://subscribe.publicmobile.ca/en/ab/activation/plans/50GB-5Gspeed14
$34/30 days for 50 GB 5G data.
You can change at next renewal.
