03-16-2024
09:06 PM
03-17-2024
01:02 AM
computergeek541
When I try to continue my activation, I get the following error, error code: XXX.
Can anyone help me?
03-16-2024 09:43 PM
wherey you got that error? I just joined and find the activation went very well using the app.
03-16-2024 09:08 PM
@Sen2024 Are you using the app to activate ? You need the app not website . If same issue with app please
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
03-16-2024 09:07 PM
HI @Sen2024
were you using the app to activate the new account? If not, please download the app
or if you were using the app, you might need to uninstall and reinstall the app
if that does not help, you will need CS agent to help out, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
