09-24-2019 01:54 PM - edited 01-05-2022 07:15 AM
Hello,
I need to change my current plan to be able to call to US from Canada and also call from US to US or Canada - I need limited data roaming while in the US and 1G data in Canada.
The $60 plan which travelers love says it is Canada / US Talk & Text. Is this all calls/text to canada and US while both in Canada and US?
Thank you
09-25-2019 03:06 AM
@Anonymous wrote:
@Spublic wrote:Hello,
Very reasonable...if moving from the $40 or $50 plan its a deal....only $10-$20 more for 30 days of text/call and 2gb....the 10 day add on all in is $20. If your on the $25 or less then look at getting an add on or a US provider prepaid cheap plan.
Thank you
Yes.
You might also look at the 10 day roaming add-ons depending on your frequency in the US.
09-24-2019 02:08 PM - edited 09-24-2019 02:11 PM
Unfortunately the only plan that does that is 60, you have no other choice. And i just read it is only temporarily option
Does your phone have double sim? Check out freedompop.com they even have free limited plans. You have to bye careful with overages with them
Maybe it would be cheaper to get 2g budget plan in usa, done of them have free call and data roaming in Canada
09-24-2019 01:58 PM
Thank you
It is both for when you are in either country. The data is split though you have 8GB while in Canada and you will have 2GB for when you are in the US all amounts are per 30 days
09-24-2019 01:57 PM - edited 04-04-2020 09:16 PM
Stay Safe!
09-24-2019 01:57 PM
Thank you
Yes.
