No Service on iPhone 5s
04-22-2019 10:21 PM - edited 01-05-2022 07:15 AM
My iPhone 5s has trouble connecting to service and constantly says "No Service" or has 1 bar intermittently. I've read through other posts with similar issues and the general consensus is that the port is stuck.
The phone is on the latest iOS software and the latest carrier firmware – IIRC 36. Weirdly, when I go into her APN settings it only shows "Personal Hotspot" no "Cellular Data", "MMS" or anything else, I'm not sure if this has something to do with it. I have downloaded a Config Profile from unlocking.co.nz that supposedly sets the APN correctly, but this didn't seem to have any effect.
Service
04-22-2019 11:03 PM
One bar... I would test with a sim from a different provider (Not bell or tellus) to see if there is a net work issue.
You can...
Check coverage in your area
Try your phone on another network
Make sure your phone is compatible with the Telus/PM network
Has your phone ever worked with PM?
04-22-2019 10:58 PM
@Nqiik wrote:My iPhone 5s has trouble connecting to service and constantly says "No Service" or has 1 bar intermittently. I've read through other posts with similar issues and the general consensus is that the port is stuck.
Are you able to test the SIM in another phone?
Figure out No Service or bad reception first before tackling APN settings as APN has nothing to do with the problem you're having.
Antennas could be a problem. Maybe have an Apple store look at it to see if the antenna has become loose.
04-22-2019 10:31 PM
I don’t have a iPhone, but I would suggest turn off “Personal Hotspot “ at setting.
