Bad Network, Call dropping every 10min and Not getting 4G speed as promised.
bimbular
I've been having issues for since past week when I switch from Rogers to Public Mobile due to the new promotion. My Phone calls randomly dropping multiple times followed by issues with even being able to receive or accept a phone call from the person I was just on the phone with. Sometime is will shows not network and will keep searching. I have never experience this issue before since I’ve been using a cell phone. This is embarrassing and annoying. I have Samsung S22 Ultra.
I have tried below methods and issue still persists.
  1. I went to settings > general > software update. You can always try putting the phone in airplane mode for 10 seconds then switch it back to regular.
  2. I removed and reinserting your SIM card with no help
  3. I also put the sim card in another phone to see  and  the issue persists
  4. I did update and reinserted my sim card and still not resolve.
  5. I have tried restarting the phone and updating it too but nothing seems to be working.
I think I might need to switch back to my Rogers because this is unacceptable.
11 REPLIES 11
bimbular
i dont check but very slow
@bimbular   how slow?  what speed you got?
bimbular
same issue... slow network unless i connected to wifi.
sheytoon
What happened when you tried your SIM in another phone?
Do you have these issues in one area or all over Toronto?
DDM69
I assure you, this is not normal. Someone will be able to help you resolve this. The Telus Network is very good.
@bimbular
Toronto has had issues this past year... first try resetting your network settings
1. Open Settings>General Management>Reset
2. Tap Reset Network Settings>Tap Reset Settings
If prompted enter your pin, passcode
3. Tap Reset Settings 1 more time to confirm
4. Restart
if that doesn't work contact customer support
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
CSA are available from
- Monday to Friday: 6AM- 10PM EST
- Saturday and Sunday: 6AM- 10PM EST
bimbular
No, I'm  in Toronto.
@bimbular   What speed are you getting?
bimbular
Ok...the point of switching was because of 4G speed.
@bimbular   for phone call, PM uses 3G network for voice calls.  (We don't have VoLTE yet, but it should be coming soon).  It could be that there is issue with 3G in your area or could be there is weak 3G signals there.  Did you try your service in different area and maybe you get better experience with voice
With 4G speed,  it takes 48 hours for the new speed to kick in.  Try using speed test app and test in different area.  Let us know what speed you are getting.  It could go as high as 100Mpbs, but it could be a bit less
