Autopay and loyalty program is gone?
Geez
I used to save $5 with autopay and loyalty program, but now new points system take it away?? Are there ways to collect points besides paying autopay?
Moved:
It is against Community guidelines for members to post referral codes here
Dunkman
@Geez
Which plan are you on? You may want to have a look at some of the new PM plans.
You may want to consider these following plans:
$19/month for 1 GB LTE
$29/month for 10 GB LTE
$34/month for 50 GB Canada/US LTE
$40/month for 75 GB Canada/US LTE
Some of these plans may be cheaper than some of the grandfathered plans.
For example, it makes sense for any old $25 plan 1GB 3G to switch over to the $19 plan.  Basically paying the same without the legacy rewards (ie. autopay and loyalty).
Phil_Adelphus
@Geez  There is no more $2 for autopay and no points for it either.  You get 5% in points on payments, and ten points annually for loyalty, referrals are still 1 point/$1.  Unless you're on the $15 plan you might want to check in your account for new subscriptions that are less than the previous ones, for example the $19 for 1GB at 4G speed instead of the old $25 plan.
There are no points given for autopay and loyalty points only amount to 10 points per year.  Points for Community participation and for referring customers work in the same way they did in the old rewards program with the exception that points need to be manually redeemed.
