eSim
JLH79
I cannot buy and install a eSim with my iphone 12 through the app.
Is there another way?
8 REPLIES 8
@JLH79
try click "Pay $5.65 and install" or "Pay and install"
again, if not works, you need to open ticket with support for them to help to buy esim
@JLH79   So when you scroll to reveal the pay and install button you press it but nothing happens?
JLH79
@JLH79
some had the same issue with the Pay and install button hidden somewhere
What phone do you have? I wonder if it is due to resolutions you chose or font size might be too big.  Did you try to make the phone portrait and landscape mode,  or  can you try to change the display resolutions to show more or smaller font size?
Or try  to uninstall the app, reboot and reinstall the app and re-puchase the esim on the app
if still cannot buy or install esim, please open ticket with support support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
JLH79
Existing customer switching from physical sim to esim
@JLH79  Are you an existing customer, new customer, switching from physical sim to esim, switching to new phone?
JLH79
I press on the (Pay $5.65 and Install) button and nothing happens.
There is a screen behind with a (Cancel) and (Pay And Install) option but I cannot access the (Pay And Install) button
Phil_Adelphus
@JLH79  Can you give us more details (nothing personally identifiable), what happens when you try?
