08-18-2019 09:12 AM - edited 01-05-2022 08:35 AM
I just received a new credit card with same number but different expiring date and code on the back of card. Do I need to tell public mobile this? I tired to do it through my account but didn't change.
Can someone help? thanks a lot
11-17-2020 04:27 PM
@betty2 wrote:i get so stressed trying to get help on this public mobile
See your post here:
11-17-2020 04:27 PM
11-17-2020 04:24 PM
05-31-2020 09:03 AM
To update your card info clear your browser, open only one tab in secret/incognito mode using firefox, chrome or safari. Go to the payment page. Scroll down to the bottom of the page to "manage card". Click on it. You'll see "remove card" and "replace card". I prefer to use replace card. Enter your billing information using ALL CAPS. Once updated make a payment and reactivate if necessary. Reboot phone. If it wont take payment try to do this thru 611.
05-31-2020 08:54 AM
Was your renewal overnight? Are there enough funds in the account and it won't reactivate? Or do you need to update the card info first?
05-31-2020 08:31 AM
Having the same issue with new credit card info but my phones will not reactivate
08-18-2019 10:29 AM
If the above suggestions don't work, the website is finicky at times. You could try a different web brwoser, clearing cache or incognito mode.
08-18-2019 09:23 AM
@ChuckYeah wrote:Here's a quick set of directions from @sandpublic .
Change the expiry date and your three digit code on the back of the card, I think.
08-18-2019 09:21 AM
08-18-2019 09:15 AM - edited 08-18-2019 09:17 AM
@melchen2001 hi yes you need to go into your self serve account and delete old card and put new one in its place under manage my card
