12-18-2019 12:07 PM - edited 01-05-2022 08:35 AM
I've had this on my plan for a while but would this include pictures/video or is that a seperate thing?
12-18-2019 03:07 PM
@wetcoaster wrote:"through your phone's accordingly set texting app, without hitting your data bucket"
Yes.
I use the Google messaging app.
@will13am wrote:Here's a discussion from the archives on maximum file size for MMS. Looks like around 1Mbyte. If RCS is used, I think the limit is 100 MBytes. Note that Public Mobile does not officially support RCS however it can still be enabled complements of Google.
https://productioncommunity.publicmobile.ca/t5/Discussions/Data-limit-for-MMS/td-p/81051
I have RCS enabled with the activity launcher work around.
12-18-2019 01:06 PM
@splynch wrote:I've had this on my plan for a while but would this include pictures/video or is that a seperate thing?
Yes, plans include pictures/short vids sending that are within MMS size.
12-18-2019 12:55 PM
12-18-2019 12:48 PM - edited 12-18-2019 12:49 PM
@Ed404 wrote:
@wetcoaster wrote:My bad. Reading and posting on the phone, plus multitasking - I was thinking of the MMS question.
No, video CALLS, are going through a messaging app and are counting on the data counter. Sorry to crash your excitement.
So I can send pictures and videos, just not video call?
Yes.
12-18-2019 12:43 PM
12-18-2019 12:37 PM - edited 12-18-2019 12:43 PM
@Ed404 wrote:
@wetcoaster wrote:
@Ed404 wrote:Does video calling require data or does it run off the texting multimedia data thing?
Your data connection needs to be on and working (APN settings!). But it's not counting on the data counter of your plan.
You don't need data in your plan for MMS to work, in the usage history it shows as "web" event.
Make sure your phone settings are configured accordingly. iMessage for example will send over a full data connection (= "data" event that counts as data) unless "told" otherwise.
So I can video call without eating up my 250MB data? COOL
No, video CALLS are going through a (messaging) app (FaceTime, WhatsApp etc) and are counting on the data counter. Sorry to crash your excitement.
12-18-2019 12:33 PM - edited 12-18-2019 12:33 PM
12-18-2019 12:26 PM - edited 12-18-2019 12:28 PM
12-18-2019 12:18 PM
12-18-2019 12:16 PM
Yes mms is included. If you have problem sending/receiving please not that most of phones need data enabled ande that the apn settings have to be correct
12-18-2019 12:14 PM
@splynchPublic mobile is pay as you go, pay before. So you never have to worry about charges for things later. Either it works, or it doesn't. MMS (multimedia messages) have restrictions size as data size, image resolution, video length etc and is highly compressed by the phone to send on the network.
12-18-2019 12:13 PM - edited 12-18-2019 12:15 PM
Yes, MMS is included.
12-18-2019 12:11 PM
Picture texting OK,not sure about vedio.
12-18-2019 12:10 PM - edited 12-18-2019 12:12 PM
