Applying Refer-a-Friend rewards after activation
Lpmailhot
I signed up my spouse and activated her SIM but neglected to use my Refer-a-Friend code. How can I get it applied after the fact?
@Lpmailhot Try the direct message link if you can't submit a ticket.
Lpmailhot
I kept getting a 404 error when trying to ticket. I just figured out that it was probably because I was not signed in to the Community. I am confused about the need for separate accounts.
Yummy
Yes, you can do it. Contact agent for assistance.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
MrSpock
@Lpmailhot
 hi a cs agent can help you  Click here or if you are having issues with Simon you can send private message to a CS Agent here:  https://bit.ly/2GGCJzH
kb_mv
@Lpmailhot  Customer service has in the past added a referral code though they are not obligated to do so. Contact them and explain the error.
You can contact customer service one of 2 ways.
1. Open a ticket through the automated ticketing system (faster response time) by clicking the chat bubble located at the bottom right of this page or ---------->Click Me<---------- ;
2. Contact them through direct messaging at the following link (note this way may take longer for a response);
---------->Click here<----------
In either case you should receive a reply within 48 hours though they are typically much faster. Keep an eye on the envelope icon top right for replies.
@Lpmailhot
Yes, PM support can help to add it back for you.  Just open ticket with PM Support and explain the situation:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
