Anyone else having slowed down mobile data?
kchow91
Both my spouse and I are on pm. She has the 3g plan, I'm on a 4g plan. Recently out mobile data has been really slow. WhatsApp messages have the pending icon for a long time. We've started, turn on/off data, taken the sim out and cleaned it but it's just not making any difference.
jlarocque96
To answer your question first:
No I have not been having significant slowdowns, although the thing with the WhatsApp is true. Because that happens sometimes.
I feel like and it might just be because I recently switched from Bell, that the messages take a bit longer to send and receive.
I'm going to continue to monitor messaging speeds on WhatsApp.
Best of luck stranger.
@ashleyskye
Try toggling airplane mode on/off. You may have a poor connection.
@kchow91
If you are still having the same issue you should do the same.
ashleyskye
I did a few days ago. Not sure why.
Staliger
@kchow91 probable the issue is with your coverage tower. Where are you located did you look for outage in your area?
Hello @kchow91 ,
Try clearing your device's cache.
"It might be due to lots of apps on your device or the hardware of the Smartphone might be outdated or inferior, such as cheap Android devices and older Smartphones. Even so, the type of applications on your phone, cheap or high-end can actually affect your browsing speed."
Check out here: https://www.signalbooster.com/blogs/news/why-is-my-cell-phone-data-so-slow-causes-solutions#:~:text=....
mm80
It's good for me. It could be an issue with your tower.
