Any charges will occur when I switch to another pubilc plan
3 weeks ago
Just want to swith from $29 / 5G to the $19 / 1G, will be any additonal charges? Or wait till the beginning date of the next payment cycle?
Thanks!
Plans
3 weeks ago - last edited 3 weeks ago
@lxh If you don't have a problem with paying $100 up front, Telus has a yearly plan (works out at $8.33 a month) which has unlimited texts and calling plus 2GB monthly data. It's a promo so you have to use a code, but once it reverts to 400 minutes/400 texts and no data after the first year you could come back to Public Mobile on a cheaper plan. See
3 weeks ago
You are right! The lowest plan was changed 500 MB....
hi @lxh
make sure you use Change on Renewal option to make plan change so it schedule the change on next renewal date. Do not use Change now , Change now allows PM to start now with the new plan but unused days on the old one will be wasted
btw, you see the $19 plan on your My Account? usually a $29 plan subscriber won't see the $19 plan. And as of yesterday, $19 plan only has 500 Mb data. Log in My Account and see what plan available on your Change Subscription page
![](/skins/images/34AB3B0FE78BBE11DBF186F131BC3766/responsive_peak/images/icon_anonymous_message.png)
