01-28-2025
02:42 PM
01-28-2025
04:14 PM
computergeek541
I sometimes have to put a 1 before the area code when calling and sometimes I just don't have to. (For the same number that is a local number). May I know why this is? Sorry if this is a silly question, I just recently subscribed.
01-29-2025 10:19 AM
Yes. I've been dialing local and it is indeed random. This only has ever happend with public mobile. Not that it is a big deal, I was just wondering why. I appreciate any input thank you.
01-28-2025 05:39 PM
Historically local calls didn't need 1 in front, but long distance did need it.
Dialing a local number depends on your current location, not your phone number.
01-28-2025 04:23 PM
Mine is Andriod
01-28-2025 03:24 PM
01-28-2025 02:51 PM
i don't think it has anything to do with iPhone or Android or landline, it is so random
all i can say is calling with a 1 for sure work, without one, it might or might not, more a luck thing
01-28-2025 02:48 PM
This seems to be a common issue but it depends if the number is on an iPhone, Android or landline.
01-28-2025 02:44 PM
I think it is more common now that is needed
usually your phone might be smart enough to add the 1 for you, but I usually just save the 1 in my contact list as well , less trouble
