01-29-2025 10:41 AM
I’m going to be spending several months in the USA and will need to use my phone there. I’ve read mixed reviews about AT&T not being very good in that particular area, but T-Mobile is better. I wanted to know if PM uses multiple networks or if it’s just a single carrier that provides the roaming. Any help is greatly appreciated!
01-29-2025 10:46 AM
Check to see if your phone is on the whitelist to work properly in the USA and set your phone on VoLTE (voice over LTE).
01-29-2025 10:45 AM
Public Mobile uses T-Mobile, At&T and Verizon
01-29-2025 10:43 AM
hi @bobca420
T-Mobile,AT&T and Verizon
Usually leavingit with Automatic is fine, but if one does not work well, manually connect to the other two
also, better to leave the network mode to 4G or LTE (instead of 5G or automatic)
