11-27-2022 12:42 PM - edited 11-27-2022 12:45 PM
Today Nov 27th, my plan was still at $40, 5Gb 3G plan.
It should be on $40, 15Gb, 4G plan by now, since I made the plan change last month!
Can you help?
OK, I read the community thread and the Incognito browser mode corrected the issue!!
OK, I read the community thread and the Incognito browser mode corrected the issue!! Thanks.
11-27-2022 06:08 PM
Nope, she was already on the 5GB plan and I chose the 15 GB. I will tell her to contact the CS agent. Thanks
11-27-2022 06:02 PM
Hi @MommaBear there are two $40 plan s, 5 GB and 15GB, and maybe you picked the wrong one?
you can open ticket with CS agent and see if they can help to make the change now. If not, you will have to schedule the correct one for next cycle
11-27-2022 05:59 PM
Hi @hTideGnow - Yes, I did do all of the above and it didn't change.
11-27-2022 03:54 PM
Hi @MommaBear did you try clear cache first and relaunch browser and check that way?
or use Private or Incognito mode
11-27-2022 03:52 PM
My daughter had the same issue with her phone for the exact same plan. I checked her account for her but it remained the same at 5GB data and not 15 GB, so it didn't change on her renewal. I updated her account again to change on her next renewal date. Her new plan should have started on November 19th
11-27-2022 12:45 PM
Hi @watungga Maybe you just checking the cached page.
please try to clear cache and relaunch browser to check again
you can also use Private mode or Incognito mode browser to check
you should see the new plan that way
