All calls going straight to Vcml
Reens
All calls going to VCML even after I try to disable with the codes?
7 REPLIES 7
@Reens  Did you just transfer a number over to PM or try too ? I send you porting team number private message check your inbox
HI @Reens
but did you just join PM and requested porting in number? If you did, it is porting related
please call the porting support team, I will send you the phone number to your community inbox
Reens
Nope, not on DND
@Reens
If you didn’t set your phone on “Do Not Disturb” then try rebooting your phone by powering off then back on.
If that didn’t work, contact a CS_Agent at:
Phil_Adelphus
@Reens   Are you a new customer who just transferred to PM or an existing customer?
@Reens  Did you just join PM and try to port a number over ? Could be indication of a porting issues if so I’ll send you the porting team number private message and they can try trigger the port request for you
hairbag1
@Reens
did you set your phone to Do Not Disturb recently ?
