01-03-2024
12:39 PM
01-03-2024
01:21 PM
Dunkman
Hi I recently joined public mobile and I ported my number from Virgin The Number Is 250xxxxxx. The port never went through its stuck half way I need you to finish porting the number Thank you
Edit by Dunkman: removed personal information
01-03-2024 01:01 PM
This is a public forum so edit your number out by clicking on the V in circle top right.
Leave the Virgin SIM in your phone, use the PM app to start the activation.
Reply with YES to text from Virgin confirming you are porting over to PM with the 90 minute window.
Virgin SIM will continue to work for about 2 hours then power off your phone and swap to PM SIM and power back on.
01-03-2024 12:41 PM
@BrentD No worries I’ll send you the porting team number private message . They can re trigger the port request for you
01-03-2024 12:40 PM - edited 01-03-2024 12:40 PM
HI @BrentD
please remove your phone number, you don't want to post your number for everyone
did you provide the account number ?
You can call Public Mobile porting team to provide the correct Info and get status update. I will send you the porting team number. Please check your Community inbox for my message
