Adding purchase
Kmonforte
I purchased US talk tex data on July 22 and didn’t receive texting service till July 24, 7:30pm. What is my recourse?
Hi @Kmonforte ,
as you got the service late, probably you should contact CS agent and express your frustration and ask for some compensation
to open ticket with CS Agent:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
  1. start by typing : Contact CS Agent
  2. then Click "Contact Us"
  3. then Click "Other"
  4. finally Click "Click here to submit a ticket"
dabr
@Kmonforte    Submit a ticket via chatbot and ask customer support as to why you weren't able to use your roaming add-on after purchasing it.  Perhaps they will offer an account credit for some or all of the cost of it, although no guarantees.
Here's a link to the chatbot:   https://www.publicmobile.ca/en/on/get-help
edit:  If unable to submit a ticket, then send a private message to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Timer
@Kmonforte
use browser from computer, clear cache and cookies and use one page inPrivate mode,
Login Page
check it out the add-oms is showing in your account.
