02-13-2023 07:54 PM
I purchased the wrong add on. Instead of the US data I wanted the Canada one.
Add-Ons
02-13-2023 08:32 PM - edited 02-13-2023 08:53 PM
@computergeek541 wrote:
@ibrahimadar22 wrote:I purchased the wrong add on. Instead of the US data I wanted the Canada one.
While a customer support agent might issue a credit, all sales are generally final. To ask Public Mobile for help, please open a ticket using the chatbot. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
I acknowledge the 'no refund' mantra around here (heck, another customer chastised me for using it a couple weeks ago...even though it's not MY policy, it's theirs).
I even agree with it as far as plan cycles go and when doing immediate plan changes. Makes perfect sense.
However, with this kind of a request, if a user hasn't used any part of an add-on and it's recently purchased, wouldn't CSA's almost always at least credit the purchase amount to one's available funds for use to purchase the desired add-on?
Surely Public Mobile management must provide clear direction to CSA's about this likely common request given the level of confusion experienced.
( EDIT: @computergeek541 , another user private messaged me wondering why I asked you this. Just want to clarify that I'm not disagreeing with your messaging whatsoever; I'm moreso wondering if the Oracles may be aware if there may be more certainty surrounding offering credits to available funds vs straight refunds to payment cards in the situation described. That's all. Thanks 🙂 )
02-13-2023 08:20 PM
HI @ibrahimadar22 you got roaming data instead?
PM is a prepaid provider, they usually do not provide refund. But still try to open ticket and they might be able to help switch the addon or issue a credit back to your account
to open ticket with CS agent, at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
02-13-2023 07:57 PM - edited 02-13-2023 07:57 PM
Contact customer support and explain your mistake. They will remove the US Roaming data add on and add the Canadian data add on. Any difference in price will be credited to your account. Submit a ticket via SIMon or if he gives you a hard time then send a private message after reading the spoiler in the post below....
02-13-2023 07:55 PM
02-13-2023 07:55 PM
them can be removeing and to added other one but you need to open a ticket with SIMon Chatboth
typ: Agent
and Click, Contact Us
then Click, Other
and, Click here to submit a ticket.
or send a private message to CS_Agent
here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
