02-13-2023 03:51 PM
I get through the whole process to register my new sim card but it won't accept my Debit Visa to finalize the process and pay for the plan?
02-13-2023 08:23 PM
HI @raygodwin glad it works.
Yes, please keep in mind that the My Account site has some cache problem.
If you login to My Account and check usage, also click the refresh spinner for update (just in case)
or some people would simply use Incognito/Private/Secret mode to login to avoid the cache problem
02-13-2023 07:54 PM
Everything worked out well, Thanks Everyone for your help! I just opened an incognito tab and started over and it worked perfectly.
02-13-2023 04:06 PM
@raygodwin wrote:I get through the whole process to register my new sim card but it won't accept my Debit Visa to finalize the process and pay for the plan?
@raygodwin - are you able to log into MyAccount/Self Serve with the email and password you selected? If so, then you activated the SIM card.
Try the SIM Card into a phone, restart it, then see if you have any services. If you do, then the SIM card activation took place.
And yes, as already mentioned, if you were charged then the activation took place; the only thing with this, IS, the charge will probably only be showing as a 'pending' charge, so it is hard to know for sure if the transaction will go into authorized state.
You could try clicking this link to use the: Public Mobile Online Activation Assistance and inquire if the SIM card shows activated on their end.
If still issues after that, go to the bottom of the Community page to submit a ticket with Customer Support using the SIMon Chatbot option.
02-13-2023 03:55 PM
@raygodwin seems odd. I'd check your card details and try again. Good luck.
02-13-2023 03:53 PM
HI @raygodwin What was the error message?
do you have another card to try?
Try to activate again using Incognit/Private/Secret mode
02-13-2023 03:52 PM
@raygodwin sorry to ask this but had it expired by any chance ?
02-13-2023 03:52 PM
@raygodwin first check your credit card to make sure PM didn't charge you, just to confirm
If you are in no rush, wait a full hour before trying again. Please access the activation site using Incognito mode
See how it goes
