05-21-2025
03:15 PM
05-21-2025
03:42 PM
computergeek541
Recently when I entered the US with the CAN US MEX plan I was not able to connect to the network even with the Data Roaming option on on my phone. I have a Samsung S24 ultra. I had to purchase a 15 day US roaming addon to use my data. Please advice if there is anything else I need to do.
05-21-2025 08:32 PM
PM is an online service so all communication is done through dm a CS_Agent.
You can click on the Chat icon and type in Submit a Ticket or:
Keep your eyes on Messages in your avatar. Staff hours are 9:00am to 10:00pm EST.
05-21-2025 06:20 PM
I had the same feeling, but I was able to connect to the network only after buying the add-on.
05-21-2025 06:19 PM
Is there a customer care department with Public Mobile? If so whats the number.
05-21-2025 05:21 PM - edited 05-21-2025 05:21 PM
Manually connect to AT&T, T-Mobile or Verizon network and see if that helps.
Since you have the Canada/USA/Mexico plan. You can contact a CS_Agent and ask for a credit into your account for the purchase of the Roaming Add-on that you didn’t need to purchase.
05-21-2025 03:45 PM - edited 05-21-2025 03:46 PM
@Sumchans wrote:Recently when I entered the US with the CAN US MEX plan I was not able to connect to the network even with the Data Roaming option on on my phone. I have a Samsung S24 ultra. I had to purchase a 15 day US roaming addon to use my data. Please advice if there is anything else I need to do.
The purchase of a 15 day US roaming add-on was not required. There could have been some strange system issue that go reset after purchasing the add-on, but the US roaming add-on doesn't actually provide any extra service or features when a customer already has a Canada-US-Mexico plan. Were you out of data on your main plan? That's the only time I could possibly see the roaming add-on being of any use.
