Add on
jbarnett
How do I cancel a data add on?
TheGx
@jbarnett :If you bought the wrong add-on by mistake you can try contact the Moderator Team and explain it to them to see if they help you. The add-ons don't renew automatically each month so no need to cancel them if you only want to buy them once.
HALIMACS
Add-ons are good til used (except the roaming add-ons which expire 10 days after purchase)
Don't worry, they don't 'renew' on every subsequent renewal date costing you more than your plan amount  - they are 1-time purchases.  If you need them every cycle, you'll have to re-purchase them to get them again.
If you made the WRONG add-on selection, try contacting the Moderators to politely request they switch to another available add-on.  No guarantees - however they would hopefully recognize human error and switch to another one.   (Refunds likely not gonna happen if simply buyer's remorse...)
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator assistance, then select account-related issue, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
darlicious
@jbarnett
There is no need to cancel an add on **bleep** are one time purchases that stay on your account until completely used up or in the case of US roaming add ons....expire. Unless you made a mistake.....
Edit: oops....."they"....dang smut filter going after my typos.....
