Add on
Dagger
Purchased an add-on and it’s not working
hairbag1
@Dagger
so which add-on did you purchase ? Did you get the Long Distance add-on, or the US Roaming add-on...give us a hint ?
hi @Dagger
what addon you got??
try reboot phone first
still not work?? check My Account using Incognito/private/secret mode on your browser and check payment history and confirm if the purchase was completed
@Dagger  First reboot the phone . Is it a U.S. roaming add on or just a regular data add on ?
Chalupa_Batman
Hello @Dagger
What add on did you purchase? Also, if you log into your account, does the add on show on your add on list?
HALIMACS
Try rebooting your device @Dagger
If you're looking to use a US Roaming add-on, you'll need to toggle on Roaming and connect to the T-Mobile network (or possibly AT&T).
