Add on text USA 10 days
Jencho
I have voicemail with my plan but after I add on USA text only.
I come back to Canada and voicemail disappear.
Did anyone had this same problem?.
Jencho
@Jencho Not sure what disappear means. If you dial area code + 580-4001 can you access your VM? If yes, then check your device settings to mske sure the weren't changed.
shskr
  you can send them a private message here: link
Moderators can take anywhere from 2 to 48 hours, depending on how many customers are ahead of you.
hairbag1
There can be unexplained glitches after the 10 Day Roaming Add-ons expire, but this is a new one. Try cylcing phone off/on. Try the lost /stolen trick. If all else fails by morning, send a message to moderators for their assistance.
Good luck.
Jencho
