08-09-2019 11:28 PM - edited 01-05-2022 06:21 AM
08-09-2019 11:32 PM
@proza , all plan data run on the LTE network. Most plans these days have so called 3G speed which means they throttle the speed but you stay on the LTE network for improved latency.
08-09-2019 11:31 PM - edited 08-09-2019 11:32 PM
@proza wrote:The data of all plans are 3G only, except for the $30 30 day 1GB?
All Public Mobile data packages will work on either the HSPA+ or LTE+ networks. Any plan that is advertised as "3g" has speeds limited to 3Mbps when connected to the LTE network.
There are higher speed LTE plans available at different price points.
08-09-2019 11:31 PM
If you look in the Build Your Own Plan section, there are some 4G LTE data plans available.
